after updating the Software the decoder will not work. The button "Digi" is disabled. I cannot select the function.
The rest is fine.
Updating ATS25 max decoder from 4.17 to 4.2
Go to setup,
go to choosing a model
then in the screen you see general,
turn the knop till you see the correct model and sellect that.
system will reboot and works,
greath job by the programmers. excelent
hi team
do we need to purchase a new license key when going from 4.16 to higher version ?
thanks for your help
cheers
cheers
nocthulhu_president писал(а): ↑29 апр 2024, 23:57 do we need to purchase a new license key when going from 4.16 to higher version ?
