updating ATS25 max? so I can use my wifi connection?
dvdkerck@gmail.com
Сообщение dvdkerck@gmail.com »
I have a ATS25 max
can I update the software so I can use my WIFI connection
on the backside I 'see' a wifi connection, and there was also a wifi antenne included
thanks in advance
Dirk
Благодарил (а): 28 раз
dvdkerck@gmail.com, If the receiver has a firmware other than H-RADIO installed, then you need to install the H-RADIO firmware for Wi-Fi to work. You will find everything you need on the Download page. You will need an activation key to activate the firmware. You can buy a key in a special section of this forum.
Atsxkey
Сообщение Atsxkey »
if need licence key can mail me
atsxkey@gmail.com
