ATS-120
OM7AVR
ATS-120
Сообщение OM7AVR »
Привет, Binns!
Не могли бы вы опубликовать производственную документацию — файлы Gerber для платы Digi Decoder?
Это было бы большим подспорьем в изготовлении самого Декодера.
Заранее большое спасибо.
Vladimir , OM7AVR
ATS-120
aresjose писал(а): 16 сен 2023, 07:33
Now the problem I have is that I cannot link the radio to any Bluetooth device, which apparently activates but does not link, maybe someone can help me with this problem.
Thank you so much..
Good afternoon, I would like to know if you have solved your problem with bluetooth? I have a similar problem, bluetooth is activated but neither the computer nor the phone can see the receiver.
Благодарил (а): 17 раз
ATS-120
Potan писал(а): 21 дек 2023, 12:43
Thank you so much..
Bluetooth is used for audio output. You can only connect audio playback devices
Deco44
ATS-120
Сообщение Deco44 »
Hello Bernard...
When will ATS120 keys be available to buy again for 9 euros via Paypal?
(see forum from September 13th)
Keys are currently offered for up to 24 euros!!!! If you then buy a decoder for around 50 euros, it's 74 euros.!!!! That's too expensive …....
It would be nice if the key cost less again...
73 by Deco44
ATS-120
Deco44 писал(а): 22 дек 2023, 18:56 Hello Bernard...
73 by Deco44
Unfortunately, it doesn't depend on me. This is PayPal's policy. There is another way to buy a key. Use a WebMoney wallet Z788269373638
Deco44
ATS-120
Сообщение Deco44 »
Thanks Bernard for the quick answer...
I'm thinking about how to do it...
73
kazu118
ATS-120
Сообщение kazu118 »
Hi.
I purchased ATS-120D and updated the firmware to 4.17Air b since there is no WIFI.
Then I could use WIFI, but LNA and Bluetooth became completely unusable.
I'm in trouble! Please give me advice.
The original firmware was 5.2b_Dark with LNA and Bluetooth enabled.
ATS-120
kazu118, You should install the ATS120 version
kazu118
ATS-120
Сообщение kazu118 »
After editing setting.ini and updating the firmware, the problem was resolved.
thank you.
Владимир Л
ATS-120
Сообщение Владимир Л »
Приветствую!
ATS 120 Pro v4.17 AIR, получил вчера.
После установки драйвера и A эксплорера PC не видит приёмник.
Использую родной кабель.
Хочу установить русский язык.
