Language
Jarbol
Language
Сообщение Jarbol »
Okay, I'll do it. I understand what you mean about diacritics.
SP6VWN
Jarbol
Language
Сообщение Jarbol »
Binns писал(а): ↑06 июл 2023, 11:00
Jarbol писал(а): ↑05 июл 2023, 22:34 Good morning, translate a language file into Polish. Maybe someone will like it?
https://drive.google.com/file/d/1s6sKtF ... drive_link
The language file can contain only 26 letters of the English alphabet and 32 letters of the Russian alphabet. This allows you to use less device memory. Will you be able to redo your file so that it contains only these letters?
I already corrected. It's on the same link, so you can: https://drive.google.com/file/d/1s6sKtF ... drive_link
SP6VWN
Language
Jarbol писал(а): ↑06 июл 2023, 11:44
Excellent. I found a couple more characters that will not be displayed on the receiver, but I can already fix this file and use it in further work. Thank you.
Jarbol
Language
Сообщение Jarbol »
I'm curious which characters these are, because I tried to remove everything related to a given language (all diacritics) so that only the basic alphabet remained.
SP6VWN
Language
Jarbol писал(а): ↑06 июл 2023, 12:23 I'm curious which characters these are, because I tried to remove everything related to a given language (all diacritics) so that only the basic alphabet remained.
Jarbol
Language
Сообщение Jarbol »
You're right. I have now corrected these shortcomings. Please check. The link to the file is the same.
SP6VWN
Language
Jarbol писал(а): ↑06 июл 2023, 22:20 You're right. I have now corrected these shortcomings. Please check. The link to the file is the same.
Yes. Thanks. I added this file to firmware
Zoltan
Language
Сообщение Zoltan »
Hi all,
I made a Hungarian translation, but it won't work because the character set in the display font is not suitable. Perhaps, in a future release, would it be possible to either migrate away from this limited character set, or install some notation system in the language file so that the appropriate character set would be loaded?
I polished a little bit on the English, hope this helps.
Z
hun.lng.zip
(2.14 КБ) 394 скачивания
eng2.lng.zip
(2.21 КБ) 414 скачиваний
