Страница 1 из 2
Language
Добавлено: 06 апр 2023, 16:56
plutoplutone
Hi, I've installed the version 4.14, but I aven't been to change the language because not indicated on setup.
Thanks.
Language
Добавлено: 06 апр 2023, 20:04
plutoplutone, What language do you want to install?
Language
Добавлено: 06 апр 2023, 21:38
plutoplutone
Italian. In the folder SPIFFS I've found the translation but Idon't know how to apply her.
Language
Добавлено: 07 апр 2023, 12:23
plutoplutone, Use the A-explorer program http://harduino.ru/files/TOOLS/A-Explorer.zip to upload to the receiver
Language
Добавлено: 07 апр 2023, 14:00
plutoplutone
Thanks
Language
Добавлено: 13 май 2023, 14:41
piccolaafita
Greetings. I have successfully updated my ATS25X2 to version 4.15 but I cannot install the Italian language because the A-explorer program is seen as malware by my antivirus (Bitdefender) and therefore blocked and quarantined. I tried disabling the antivirus and whitelisting the A-Explorer.exe file but clicking on this file the program does not start ... I use Windows 11 ...
Language
Добавлено: 14 май 2023, 17:43
pp5rd
I suggest you to review your antivirus settings, A-explorer is working fine here, I'm also use Windows 11 and my antivirus is Karspersky and had no problems at all.
Language
Добавлено: 17 май 2023, 14:56
pp5fmm
Brazilian Portuguese file available.
Mateus PP5FMM
Language
Добавлено: 05 июл 2023, 22:34
Jarbol
Good morning, translate a language file into Polish. Maybe someone will like it?
https://drive.google.com/file/d/1s6sKtF ... drive_link
Language
Добавлено: 06 июл 2023, 11:00
Jarbol писал(а): ↑05 июл 2023, 22:34 Good morning, translate a language file into Polish. Maybe someone will like it?
The language file can contain only 26 letters of the English alphabet and 32 letters of the Russian alphabet. This allows you to use less device memory. Will you be able to redo your file so that it contains only these letters?
