Страница 1 из 5
Firmware 4.2 ?
Добавлено: 18 июн 2024, 09:21
radi0
Good morning,
What are the differences between version 4.17 and
version 4.2 ?
I have the ATS25 AMP is it compatible ?
does version 4.2 have psk31 decoding ?
Thank you for your answers, have a nice day everyone
:D
Firmware 4.2 ?
Добавлено: 26 июн 2024, 22:53
All of the changes are covered in the changelog (see below).
- The latest 4.2 beta firmware is compatible with the ATS25-AMP.
- PSK decoding is supported.
When the new firmware is installed, you will need to make sure you select the correct receiver type in the configuration, otherwise the receiver will not operate as expected.
It should be noted that the additional frequency bands requires a hardware modification which is not so straight forward for the ATS25-AMP.
An outline of a possible modification is provided in the link below. Further discussions can be found on the forum.
viewtopic.php?t=11&start=22
======== H-RADIO v4.2 ========
AIR beta 04/25/2024
04/25/2024
ATTENTION!!! Receivers with ST7789 (ATS200) and ST7796 screens must install this update using a PC.
- Fixed an error when updating via the Internet for receivers with ST7789 and ST7796 screens.
- Added scrolling of the list of changes when updating using the encoder.
- Fixed a bug when deleting a city without deleting stations, which led to clearing the name of the stations.
- Fixed incorrect installation of GPO1 and GPO2 for some receiver models.
- Fixed freezing issue when selecting a Wi-Fi access point.
- Added automatic setting of the lower limit of the FM band for ITU region 2.
- Fixed a bug when selecting NFM modulation in CB mode with a missing mixer.
- Changed the panel colors when adjusting the volume and in FM and CB modes in accordance with the selected color theme of the buttons.
04/15/2024
- Added a translation into Czech. Thanks to lukas maly.
- Fixed the operation of the automatic antenna input switch.
- Fixed interface display errors.
- Fixed the operation of the noise canceller in SSB mode.
- Optimized button output. Now custom buttons are not used. 32 button display options have been added to the settings.
- Added a screen lock to the menu that is called by clicking on the indicator. It is possible to turn off the touch screen to minimize interference. To turn on the touch screen, press the encoder.
- Added support for PSK decoding.
- Fixed the error of incomplete output of decoded data for the vertical screen.
- Added accelerated frequency adjustment when the encoder rotates rapidly.
- Changed the sideband selection for CW and CWR to reverse in accordance with the standard.
- Improved waterfall display algorithm.
- Improved the display of the status bar for visual perception.
- The SI473x control pin inversion SETUP has been introduced to support various receiver circuits.
- Improved range scanning algorithm. The scan step has been changed and synchronized with the setup step for a better result.
- Fixed stereo mode for FM.
- Fixed a setting error in DV for Retro mode.
- Added the ability to view hidden characters when entering passwords.
- Changed variable names for ESP32 pins in the setting.ini file.
- Fixed a hang on reboot.
- Added an update via the Internet.
- Added download of localization files and additional files from the update server.
- Added support for the ST7789 and ST7796 screens.
- The battery level scale as a percentage has been changed to logarithmic for a more accurate estimate of the remaining operating time.
- Added automatic parameter setting depending on the receiver model. The model can be installed in SETUP.
- Added manual date and time entry. It is possible to do this in SETUP and in FT protocol decoding mode.
- Added mixer support for receiving the VHF band.
- Added a pseudo NFM demodulator for a range of 10 meters and CB.
- Added new setting step values for the VHF range.
- Added settings for the screen, encoder, Internet connection, interface language, location and list of FM stations when first turned on.
- Fixed a scale error when turning on the 200 kHz tuning step in the FM band.
- Added an indication of the switched-on noise canceller.
- Added support for additional time zones.
- The algorithm for processing the running line has been changed for greater smoothness.
- Added scanning of the frequency list for simultaneous listening. Setting up the list in FREQ -> SCAN.
- The update message is now displayed once. You can check for updates in SETUP.
- Added a mute function when turned on.
- Added the ability to view the latest downloaded information about the passage of waves in INFO, regardless of the current Internet connection.
- Fixed switching of HF filters for ATS25AMP and ATS25 max-Decoder II receivers.
- Fixed incorrect frequency display in SCAN after turning on the screen saver.
Firmware 4.2 ?
Добавлено: 01 сен 2024, 18:15
radi0
Thank you Dave for the response
8-)
Firmware 4.2 ?
Добавлено: 28 ноя 2024, 10:25
Sarw
Здравствуйте! Если возможно, пожадуйста уберите кнопки включения FM и RDS с основного экрана! ФМ и так теперь есть в каждом утюге, эти аппараты покупают не ради ФМ ((( Кнопка включения FM расположена там же, где и Volume (которая используется постоянно), и поэтому всё время по ошибке вместо регулировки громкости включается ФМ диапазон! Экран же маленький, сверху под углом его вообще не видно, и какая из страниц экранного меню активна на данный момент, непонятно! Просто жмешь по памяти туда, где должна быть кнопка Volume или Mute - а там ФМ ((((
Firmware 4.2 ?
Добавлено: 30 ноя 2024, 01:06
Sarw, Так вы не жмите на экран )) жмите на энкодер. Так менять громкость гораздо удобнее. Как говорится, читаем инструкцию. Там много нового узнаете.
Firmware 4.2 ?
Добавлено: 30 ноя 2024, 09:34
Sarw
Binns писал(а): ↑30 ноя 2024, 01:06 Sarw, Так вы не жмите на экран )) жмите на энкодер. Так менять громкость гораздо удобнее. Как говорится, читаем инструкцию. Там много нового узнаете.
На энкодер? Ладно, тогда оттуда уберите этот недо-шумодав на втором щелчке! Это же бесполезная хрень, которая к тому же не работает! И про "инструкцию" это сейчас смешно вы сказали, да.
Firmware 4.2 ?
Добавлено: 30 ноя 2024, 09:35
Sarw
Вы тогда вообще вернитесь лучше к варианту ATS20 без этого дурацкого сенсорного экрана, от которого только помехи. Это опять к разговору про энкодер.
Firmware 4.2 ?
Добавлено: 01 дек 2024, 14:35
Sarw, шумодав в основном для AM. Очень помогает на авиа диапазоне и при приеме сигналов в NFM модуляции на частотах VHF включая диапазон 2 метра. Но и при настройке на вещательные станции AM тоже удобно использовать. В последней версии шумодав улучшен. Теперь реагирует даже на слабые сигналы.
Что касается сенсорного экрана, то для примера приведу приемник Arinst, там тоже сенсорный экран, но помех не наблюдается. Результат схемотехнических решений по изоляции внутренних шумов от приемной части. Но это вопрос к разработчикам железа, а не софта.
Firmware 4.2 ?
Добавлено: 02 дек 2024, 09:36
Sarw
Binns писал(а): ↑01 дек 2024, 14:35 Sarw, шумодав в основном для AM. Очень помогает на авиа диапазоне и при приеме сигналов в NFM модуляции на частотах VHF включая диапазон 2 метра. Но и при настройке на вещательные станции AM тоже удобно использовать. В последней версии шумодав улучшен. Теперь реагирует даже на слабые сигналы.
Я согласен насчет железа, так я ж не предъявляю претензий по поводу помех от экрана (это боль и отдельная тема) Я про шумодав сказал потому, что вот он на втором щелчке стоит на валкодере, и когда жмешь на колесо, чтобы проскочить шумодав - случайно проворачивается колесо валкодера на несколько оборотов, и это инициирует шумодав. Я так попал при первом включении. Долго не мог понять, почему на АМ громкость отсутствует! Хорошо, люди подсказали, что шумодав на втором щелчке! Сам шумодав в принципе используется редко, а на моей модели так вообще нету авия.
Firmware 4.2 ?
Добавлено: 08 янв 2025, 16:27
Здравствуйте! Когда будет финальная версия прошивки 4.2?
