ATS25 AMP: Can't Update To 4.2: Can't Change Baud Rate
Добавлено: 03 сен 2025, 20:45
Good Evening,
I'm having trouble updating my ATS25 AMP with firmware 4.2.
The H-RADIO Installer runs with the blue window, and I follow the prompts. But the installation fails because the baud rate can't be changed to 921600 (see attachment). I've searched the forum and tried the four different installations available. I also have installed the driver each time I try to update it.
Do I have to change the baud rate manually? I can't seem to get the ESPTool to open. I am using Windows 7 within a virtual machine with Ubuntu Linux. I may be able to use Windows 10, if that helps. I've set up a COM port using the USB port and data is being copied successfully from the ATS25 to my machine before the installer attempts to update the radio.
Thank you in advance!
