ATS25 AMP upgraded to 4.2 - hi-z/50 ohms broken and FM reception degraded
Добавлено: 01 ноя 2025, 23:25
AlainFR
Hello to all,
I just upgraded my ATS25 AMP to firmware v4.2. It went smoothly, no license issue but now my receiver is stuck on Hi-Z antenna mode, the Hi-Z/50 ohms mode switches are greyed out in the setup menus.
Also, I think that FM reception is much degraded compared to 4.17 Air Beta. Maybe because of that antenna mode switch issue?
How can I fix this please? If I can't I will have no choice but return to the previous version is this is possible.
Many thanks in advance for your help.
Greets
Alain
Добавлено: 02 ноя 2025, 08:53
AlainFR писал(а): ↑01 ноя 2025, 23:25 Hello to all,
Greets
Alain
select the correct model of your receiver in SETUP
Добавлено: 02 ноя 2025, 11:28
AlainFR
Thanks for you reply.
Silly me, I had done this already but I did not realize that there were more than the two choices appearing on screen :
- a very long line of ATS25 models, it looked too long to fit on the screen. I did not see the AMP model listed in it but I assumed that it was there among the others
- generic
I had selected the first choice.
Now I have seen that there are more choices by scrolling down with the encoder wheel.
Fixed. Spassiba.
Alain
