ATS25 USB-C charging
Добавлено: 20 янв 2024, 05:25
I tried to charge my ATS25 using a google supplied USB-C power supply and cable. This doesn't work. However, using a dumb USB-C cable does work. This implies that the CC1/CC2 pins are not wired correctly on the ATS25. This is not an unusual problem, and the Raspberry Pi 4 suffered from the same problem (https://hackaday.com/2019/07/16/explori ... -in-depth/).
If there is a respin of the board in the future, then it is probably worth fixing -- it will be one or two resistors at worst.
Thanks for a great device.
