V4.2 beta - Re-calibrate screen after initial install?
falcon56215
Сообщение falcon56215 »
I have an ATS-25 MAX Decoder II. I flashed the latest firmware 4.2beta to the device. This worked. Upon initial power up I was asked to calibrate the screen. I did this and everything came up operational, but I think I missed the calibration a bit. I would like to rerun the screen calibration routine but I have not been able to find a way to do this. I flashed the old 4.17 firmware but ended up with a blank screen. I reflashed to 4.2beta but it never asks for screen calibration again. Is there a way to rerun to screen calibrate?
Благодарил (а): 27 раз
Да, при включении нажмите на энкодер, перейдете в начальную установку с калибровкой экрана.
falcon56215
I tried that before my original post. It does not work. Mine skips to internet setup and does not show the screen calibration again. I have also tried resetting to factory defaults.
У меня работает
falcon56215 писал(а): ↑22 июл 2024, 17:37 I have an ATS-25 MAX Decoder II. I flashed the latest firmware 4.2beta to the device. This worked. Upon initial power up I was asked to calibrate the screen. I did this and everything came up operational, but I think I missed the calibration a bit. I would like to rerun the screen calibration routine but I have not been able to find a way to do this. I flashed the old 4.17 firmware but ended up with a blank screen. I reflashed to 4.2beta but it never asks for screen calibration again. Is there a way to rerun to screen calibrate?
What you call screen calibration after installing firmware 4.2 is not calibration. This is the definition of the sensor coordinate axes. There is no need for precise installation, only determination of directions. Therefore, if you do not have problems with the sensor, then you do not need calibration.
