Atsxkey 2024
Atsxkey
Atsxkey 2024
Hi Mr. Wayne. I want confirmation for activation. A single sent email is enough, I will answer as soon as possible. The difference is that I work in 3 shifts and I probably have to rest as well. You have purchased a key, I am waiting for a single activation confirmation email. Did you succeed?
Гость
Atsxkey 2024
Basically, it works. The only problem I observed was that device can't connect to Internet behind double NAT. In my situation I have a DSL modem/router (with Wi-Fi function) with IP range 192.168.X.X/16 and a Wi-Fi router behind it with IP range 172.16.X.X/12. My Wi-Fi networks is from range 172.16.X.X/12. No problems with any of my devices for many years - phones, tablets, TV, some gadgets. So I connected my ATS25X2 to it and no luck with activation. Finally I activated Wi-Fi from my DSL modem, connected ATS to it and activation was successful.
Andreas
Atsxkey 2024
Ich habe den Lizenzschlüssel angefordert. Es wurde umgehend geantwortet und nach Bezahlung alle notwendigen Informationen per E-Mail gesendet. Netter Kontakt. Vielen Dank.
IBravestarr
