Language
plutoplutone
Language
Hi, I've installed the version 4.14, but I aven't been to change the language because not indicated on setup.
Thanks.
Thanks.
plutoplutone
piccolaafita
Language
Greetings. I have successfully updated my ATS25X2 to version 4.15 but I cannot install the Italian language because the A-explorer program is seen as malware by my antivirus (Bitdefender) and therefore blocked and quarantined. I tried disabling the antivirus and whitelisting the A-Explorer.exe file but clicking on this file the program does not start ... I use Windows 11 ...
Language
I suggest you to review your antivirus settings, A-explorer is working fine here, I'm also use Windows 11 and my antivirus is Karspersky and had no problems at all.
Language
Good morning, translate a language file into Polish. Maybe someone will like it?
https://drive.google.com/file/d/1s6sKtF ... drive_link
SP6VWN
Language
Jarbol писал(а): ↑05 июл 2023, 22:34 Good morning, translate a language file into Polish. Maybe someone will like it?
The language file can contain only 26 letters of the English alphabet and 32 letters of the Russian alphabet. This allows you to use less device memory. Will you be able to redo your file so that it contains only these letters?
