ATS200 Ver 4.2 problems
ats200usa
Сообщение ats200usa »
I upgraded from stock firmware to 4.2 AIR build date 23.03.2025 on my ATS200.
I have problem with AIR (aviation) band. If I select the AIR button, I get popup window "Connect the External Frequency Counter." If I try direct frequency entry from FREQ button, I get red message "not supported" next to the frequency window. The radio does receive air band transmissions - but I can only use the rotary encoder to change frequencies. This is very slow and difficult to make quick changes to air frequencies.
I used the ATS200 model in Settings. I have tried all the other models and I get same problem. I tried Generic model because the H-RADIO 4.2 manual says you can configure a special mixer for ATS200 series receivers for aviation band, but there is no such selection.
Please advise on how to fix this problem.
Other minor bugs - the waterfall does not work for ATS200 (audio spectrum and display peaks in audio spectrum greyed out) - it does work if I select ATS120 Pro+ model. Also, radio loses the date/time whenever I change bands or turn off the radio. These are minor bugs, I would like AIR to get fixed.
Please advise on what I should do next. Thank you and 73.
ats200usa, A pop -up window just ignore the press OK button. This will be fixed in the next version of the firmware. This does not affect anything. Manual frequency entry works. You must enter the frequency value in KHZ. The lack of spectrum is not a mistake, there is no decoder in ATS200, so it will not work. The clock must be installed or synchronized through Wi-Fi every time after turning on. There is no built -in Clock in the receiver.
matt5295
Сообщение matt5295 »
ATS200.... I installed firmware update and accidentally selected wrong language....I need to reset language......it let's me change itu...but not language
ats200usa
Binns - thank you for the comments. Glad to know air band entry is in kHz. Works fine. 73 :D
