Hi sirs
I have downloaded the latest 4.2 firmware on my ATS23X2 and the battery charge is extremely low to get 70% (> 20h) though before using the initial fw it was normal
The led at the back is on (red). Have tried several cables...
please help
settings.ini =
//batValueAdjust , 0 // adjusting the battery voltage value
//batEmpty , 2.7 // volt 0% battery charge
//batFull , 3.7 // volt 100% battery charge
//batMin , 2.65 // volt minimum voltage battery
//batMax , 4.35 // volt maximum voltage battery
Jean
Battery charge problem ATS25X2
Hello...for me after updating to version 4.2 the display shows the battery status 0.0V and 0%. The battery is probably charged because the charging light on the back of the radio goes out after a while, but the display still shows 0.0V/0% in both cases. I don't know why this is. In version 5.3 the battery level was displayed.
Andy
Andy
Andy
