Hi there,
On the screen of the receiver, in the setup, i can see Language : eng
Into the SPIFFS directory, there is a directory languages, but it is impossible to select another language on the radio.
How to ?
May I help you to tanslate into French ?
How to ?
Thanks
Language select
Language select
You can take the eng.lng file and translate each line in it into your language. In the first line, write "FRA, 6, latin" Then download it on the website harduino.ru the A-explorer program and use it to upload your file to the receiver. After restarting the receiver, it will be possible to change the language. The instruction is attached to the A-explorer program.f4mzi писал(а): ↑19 июн 2023, 19:59 Hi there,
How to ?
How to ?
Thanks
Language select
Hi there,
The french language file is ready.
Download it here :
https://drive.google.com/file/d/1Iaj40i ... sp=sharing
Download it here :
Pierre-Philippe
F4MZI
F4MZI
Language select
Good morning, I have prepared a translation of a language file for the Polish language. Maybe it will be included in the next versions...
https://drive.google.com/file/d/1s6sKtF ... drive_link
SP6VWN
Language select
на сайте harduino.ru в разделе скачивания скачайте ту версию прошивки, которая у вас установлена. В скачанном архиве вы найдете файл русификатора. От другой версии не подойдет.
Language select
Очень хочется версию 4 дюймового экрана - может подскажите когда ожидать - приемник понравился.
Language select
Binns, Очень хочется версию 4 дюймового экрана - может подскажите когда ожидать - приемник понравился.
Language select
I need an activation code for the ATS25 Max. I just flashed the firmware and as of right now the device is unusable. I live in the USA.
Respectfully,
Derrick Jones
Respectfully,
Derrick Jones
