TDI_Power писал(а): ↑09 июл 2023, 21:41 I believe this is a limitation of the Silicon Labs SI47xx chip.
Yes this is a limitation of the SI473x chip
XE1E
Сообщение XE1E »
I installed 4.16 Air version for ATS120 and working with no problem only minor issues.
Thanks for the effort.
73 y DX de XE1E Enrique
XE1E
ATS120 FM step problem
Сообщение XE1E »
I select 100 khz step for FM but when I turn off and on the step changes to 200 khz, is there a way to always stay in 100 khz?
Thanks in anvance for the help.
73 y DX de XE1E Enrique.
XE1E писал(а): ↑12 июл 2023, 20:18 I select 100 khz step for FM but when I turn off and on the step changes to 200 khz, is there a way to always stay in 100 khz?
By default, for the ITU region 2, the FM band pitch is 200 kHz. When the receiver is turned on, the default step is set.
XE1E
Сообщение XE1E »
Is there a way to change this default ?
I'm in Mexico ITU region 2 but here we use 100 kHz.
Thanks.
XE1E писал(а): ↑12 июл 2023, 22:06 Is there a way to change this default ?
Thanks.
only change firmware. I will consider this option in future firmware versions.
XE1E
ATS120 Retro Scale
Сообщение XE1E »
Hi
I have the behaviour show in the attached video, it is normal ?
Thanks for your comments.
ATS120 RETROSCALE.zip
(21.52 МБ) 538 скачиваний
XE1E
ATS120 WiFi
Сообщение XE1E »
Hi
Someone has tried to use an antenna connected to ESP32 for WiFi?
With no antenna the WiFi signal is very poor and useless, the case acts as a shield.
73 y DX de XE1E
XE1E писал(а): ↑15 июл 2023, 08:33 Hi
This is normal behavior. You shouldn't have created two identical cities separately for FM and AM. Combine the stations of these cities into one and select a range in the retro scale using the band button
XE1E
Сообщение XE1E »
Bernard...
Thanks for your advice, it´s now working nice.
