ATS25+
Slightly confused on procedure, doing it on web site, what key strig goes where, otherwise flowless process of activation of revision 4.2, Next day upgraded to 4.21, license not required again
License Key transaction and support
Gregoire_fronsac
Dar enormemente las gracias a atsxkey@gmail.com, primero por su gran rapidez y segundo por su gran profesionalidad.
Da gusto contactar con gente tan amable y profesional.
Atentamente recomendable.
Muchas grcs!!!
Muchas grcs!!!
Гость
thank you from the bottom of my heart.
you saved me from a mistake. quick response to emails, license received within minutes of payment. The whole process took less than 20 min.
Kind and fast, answered questions even after activation. 100% recommended
Bonjour j aurais besoin d une clé appareil bloqué comment procedé merci
marc
marc
Гость
Гость
tomazi1968
Hello. I need a license key for the ATS25X2. My email address is sq7otg@gmail.com
h-radio activated thanks to atsxkey@gmail.com.
I received the key instantly. I had some trouble with activation, but atsxkey@gmail.com helped me out, and everything is working now. Highly recommended!!!!!!
atsxkey@gmail.com
Some problem appear when try other different firmware ex ( Golden Radio) and want to return to harduino
Need esptool v3.9.9 select esp32, connect to your radio and press erase to clean memory.
Then install harduino firmware.
Before cleaning symptoms
No connect to wifi, will lock licence key and need to reset key.
