updating ATS25 max? so I can use my wifi connection?
dvdkerck@gmail.com
Сообщение dvdkerck@gmail.com »
I have a ATS25 max
can I update the software so I can use my WIFI connection
on the backside I 'see' a wifi connection, and there was also a wifi antenne included
thanks in advance
Dirk
dvdkerck@gmail.com, If the receiver has a firmware other than H-RADIO installed, then you need to install the H-RADIO firmware for Wi-Fi to work. You will find everything you need on the Download page. You will need an activation key to activate the firmware. You can buy a key in a special section of this forum.
Atsxkey
Сообщение Atsxkey »
if need licence key can mail me
atsxkey@gmail.com
svin3s@yahoo.com
Сообщение svin3s@yahoo.com »
Hello, is there any new info cc the possibility to download/receive internet radio stations via Wi-Fi connection (On ATS-25 Max Decoder)? As I saw from last November posts here, the matter was in development and new software is expected. Anything on this? Thanx!
Juergen1
Сообщение Juergen1 »
Need a key? Send an email to:
dn1hi@gmx.de
I send by mail from Germany
73
jürgen1
readt
Сообщение readt »
If your ATS25 Max already has the Wi-Fi hardware, installing the H-RADIO firmware is the main step. I'd also check that your specific board revision supports it before buying an activation key.null's brawl на ios
