FW-Update from 4.2 AIR to 4.21 Air Beta ->Problem
ponti
Сообщение ponti »
Hello Mr.Binns
If i Update my ATX25X2-mod from Firmware 4.2 AIR to 4.21 AIR beta, i geht after Restart a Warning: "Check your Key". If i go back to 4.2 AIR then everything its ok.
Whats wrong?
i Have a Valid Key for my ATS25 for long time.
73 and Greetings
Klaus , DG3VG
ponti писал(а): 14 авг 2026, 16:27 Hello Mr.Binns
Whats wrong?
73 and Greetings
Klaus , DG3VG
The receiver model is incorrectly selected in SETUP.
ponti
Сообщение ponti »
Hello
Yes, that's right—I've been experimenting with different radio versions since I have an ATS25X2 with a digital decoder retrofit. Max Decoder works, as does Generic, but Max Decoder II no longer works.
Does Max Decoder II have a different ESP? I had set it to MAX Decoder II.
Everything is working fine again with Max Decoder.
Thanks!
73
Redarrow
Сообщение Redarrow »
Please can you help me
I have a ats25 pro
My radio only works for air I suspect it's to do with an antenna even though I've got a loop antenna setup the problem I have at the moment is upgrading firmware,
I am currently on the firmware 4.2 my radio has Wi-Fi connection and when I press update to get an update of the new beta firmware it don't give the files to update the radio, or does it automatically update it self, I would like to know if the beta is working as an update directly to the radio or should I wait for the proper release.
Also
Is it true at the moment the new firmwere software is going to be released for the mini ats25 before it gets even to the ATS 25 pro air sets
Please reply .
Redarrow писал(а): 30 авг 2026, 06:37 I am currently on the firmware 4.2 my radio has Wi-Fi connection and when I press update to get an update of the new beta firmware it don't give the files to update the radio, or does it automatically update it self, I would like to know if the beta is working as an update directly to the radio or should I wait for the proper release.
If the alpha version is installed, the beta update can be installed manually using a computer. Then all beta updates will be installed via Wi‑Fi. Otherwise, only alpha firmware updates will be delivered via Wi‑Fi.
