Yes this is a limitation of the SI473x chip
ATS-120
ATS120 FM step problem
I select 100 khz step for FM but when I turn off and on the step changes to 200 khz, is there a way to always stay in 100 khz?
Thanks in anvance for the help.
73 y DX de XE1E Enrique.
By default, for the ITU region 2, the FM band pitch is 200 kHz. When the receiver is turned on, the default step is set.
Is there a way to change this default ?
I'm in Mexico ITU region 2 but here we use 100 kHz.
Thanks.
Thanks.
only change firmware. I will consider this option in future firmware versions.
ATS120 Retro Scale
Hi
I have the behaviour show in the attached video, it is normal ?
Thanks for your comments.
- Вложения
- ATS120 RETROSCALE.zip
- (21.52 МБ) 545 скачиваний
ATS120 WiFi
Hi
Someone has tried to use an antenna connected to ESP32 for WiFi?
With no antenna the WiFi signal is very poor and useless, the case acts as a shield.
73 y DX de XE1E
73 y DX de XE1E
ATS-120
This is normal behavior. You shouldn't have created two identical cities separately for FM and AM. Combine the stations of these cities into one and select a range in the retro scale using the band button
