Atsxkey 2024
Atsxkey 2024
Сообщение Atsxkey »
Hi Mr. Wayne. I want confirmation for activation. A single sent email is enough, I will answer as soon as possible. The difference is that I work in 3 shifts and I probably have to rest as well. You have purchased a key, I am waiting for a single activation confirmation email. Did you succeed? :!:
Гость
Atsxkey 2024
Сообщение Гость »
Got a working key on m radio. Quick reply to emails and clear instructions. :D
F@n
Atsxkey 2024
Сообщение F@n »
Basically, it works. The only problem I observed was that device can't connect to Internet behind double NAT. In my situation I have a DSL modem/router (with Wi-Fi function) with IP range 192.168.X.X/16 and a Wi-Fi router behind it with IP range 172.16.X.X/12. My Wi-Fi networks is from range 172.16.X.X/12. No problems with any of my devices for many years - phones, tablets, TV, some gadgets. So I connected my ATS25X2 to it and no luck with activation. Finally I activated Wi-Fi from my DSL modem, connected ATS to it and activation was successful.
Andreas
Atsxkey 2024
Сообщение Andreas »
Ich habe den Lizenzschlüssel angefordert. Es wurde umgehend geantwortet und nach Bezahlung alle notwendigen Informationen per E-Mail gesendet. Netter Kontakt. Vielen Dank. :D
Гость
Atsxkey 2024
Сообщение Гость »
Respuesta muy rapida
Muchas gracias
IBravestarr
Atsxkey 2024
Сообщение IBravestarr »
Everything was correct, very attentive and fast! 100% trustworthy.
