Marek777
Сообщение Marek777 »
Последний раз редактировалось Marek777 02 сен 2024, 11:13, всего редактировалось 1 раз.
Ats25x2 problem after update from 4.17 to 4.2
First, check whether the receiver model is selected correctly in SETUP. It will be easier to understand your problem if you attach an example video. Do you use the antenna switch on the back of the receiver when you turn on the ssb?
Marek777
