Добавлено: 29 авг 2024, 21:33
Marek777
Ats25x2 problem after update from 4.17 to 4.2
Добавлено: 30 авг 2024, 08:47
First, check whether the receiver model is selected correctly in SETUP. It will be easier to understand your problem if you attach an example video. Do you use the antenna switch on the back of the receiver when you turn on the ssb?
Добавлено: 30 авг 2024, 09:37
Marek777
