FM lower limit frequency in retro mode on ATS-25amp
Добавлено: 09 ноя 2024, 03:40
drelectron3
I am using ATS-25amp with version 4.2, and I would like to set the lower limit frequency of FM in retro mode to 70MHz, but the current setting is 87.5MHz. How can I set it to 70MHz?
Добавлено: 09 ноя 2024, 12:13
drelectron3, Enable the FM range from 64 MHz in the menu settings.
Добавлено: 09 ноя 2024, 14:20
drelectron3
Добавлено: 09 ноя 2024, 19:49
Turn on 64 MHz, , NEXT, search <<DN and that's it. That's how it worked for me.
Добавлено: 10 ноя 2024, 05:10
drelectron3
Your screen is a VHF screen, not an FM screen. I can also display from 64MHz if it is VHF. The FM screen is probably from 87.5MHz.
Добавлено: 10 ноя 2024, 05:17
drelectron3
IN VHF, the maximum freqencey is up to 87 MHZ INSTEAD.
I live in Japan.In Japan, the FM band must range from 70 MHz to 108 MHz.
Добавлено: 10 ноя 2024, 15:11
This means you need to adjust something in the program for the Japanese FM range, I can’t help you here.
