Hello,
after updating the Software the decoder will not work. The button "Digi" is disabled. I cannot select the function.
The rest is fine.
Updating ATS25 max decoder from 4.17 to 4.2
Go to setup,
go to choosing a model
then in the screen you see general,
turn the knop till you see the correct model and sellect that.
system will reboot and works,
greath job by the programmers. excelent
hi team
do we need to purchase a new license key when going from 4.16 to higher version ?
thanks for your help
cheers
cheers
nocthulhu_president писал(а): ↑29 апр 2024, 23:57 do we need to purchase a new license key when going from 4.16 to higher version ?
Hello. I have the ATS25amp, I have updated to V4.2, it asks for activation. I have a key license, unlock code and binding code. It only accepts the license code, not the others. What have I done wrong? There's a solution? Thank you so much. Sorry for the translation
Now you need to write to the support address nul@bk.ru to get help with the activation key.EA4IAM писал(а): ↑13 июл 2024, 22:17 Hello. I have the ATS25amp, I have updated to V4.2, it asks for activation. I have a key license, unlock code and binding code. It only accepts the license code, not the others. What have I done wrong? There's a solution? Thank you so much. Sorry for the translation
I have yet to update mine. I have the ATS25 MAX-Decoder Ⅱ. Great little radio. I am a little hesitant to update the firmware at this point.
