Updating ATS25 max decoder from 4.17 to 4.2
crazymike
Сообщение crazymike »
Hello,
after updating the Software the decoder will not work. The button "Digi" is disabled. I cannot select the function.
The rest is fine.
crazymike писал(а): 13 апр 2024, 07:37 Hello,
The rest is fine.
Choose your receiver model correctly in the SETUP
pa1mer
Сообщение pa1mer »
Go to setup,
go to choosing a model
then in the screen you see general,
turn the knop till you see the correct model and sellect that.
system will reboot and works,
greath job by the programmers. excelent
cthulhu_president
Сообщение cthulhu_president »
hi team
do we need to purchase a new license key when going from 4.16 to higher version ?
thanks for your help
cheers
cthulhu_president писал(а): 29 апр 2024, 23:57 do we need to purchase a new license key when going from 4.16 to higher version ?
no
EA4IAM
Сообщение EA4IAM »
Hello. I have the ATS25amp, I have updated to V4.2, it asks for activation. I have a key license, unlock code and binding code. It only accepts the license code, not the others. What have I done wrong? There's a solution? Thank you so much. Sorry for the translation
EA4IAM писал(а): 13 июл 2024, 22:17 Hello. I have the ATS25amp, I have updated to V4.2, it asks for activation. I have a key license, unlock code and binding code. It only accepts the license code, not the others. What have I done wrong? There's a solution? Thank you so much. Sorry for the translation
Now you need to write to the support address nul@bk.ru to get help with the activation key.
VLFberht
Благодарил (а): 7 раз
Сообщение VLFberht »
I have yet to update mine. I have the ATS25 MAX-Decoder Ⅱ. Great little radio. I am a little hesitant to update the firmware at this point.
