SI5351 frequency
ikuclja2
SI5351 frequency
Сообщение ikuclja2 »
Si5351 gives the wrong freq (32.773) with firmware 4.17 beta, is it possible to fix it to 32.768 in SETTING.INI?
Thank you !
Ivan
SI5351 frequency
ikuclja2 писал(а): ↑02 янв 2024, 16:25 Si5351 gives the wrong freq (32.773) with firmware 4.17 beta, is it possible to fix it to 32.768 in SETTING.INI?
Thank you !
Ivan
The frequency tuning of the si5351 generator is performed as follows: turn on any HAM band, then press BFO to switch to the tuning mode, press the BFO frequency briefly.
ikuclja2
SI5351 frequency
It doesn't work well in version 4.2, everything shows up fine on the display but it doesn't change the frequency on the Si5351
SI5351 frequency
ikuclja2, Thanks for the feedback. The error will be fixed.
SI5351 frequency
Binns писал(а): ↑04 май 2024, 11:06 ikuclja2, Thanks for the feedback. The error will be fixed.
Означает ли это, что после бета-версии 4.2 будет следующая версия?
SI5351 frequency
Arvi, вносятся исправления и выкладывается на сайте. в конце будет финальная 4.2
