ATS25 max-Decoder II FM Radio Firmware 4.2Beta
rebirthan1x
Сообщение rebirthan1x »
Hello
I have a problem after updating to firmware 4.2. The FM Radio is not working after the update, only white noise ( I came from 4.17 ). I choose the right hardware in setup.Have some else the problem? Is it possibe to downgrade? If I try it, the screen went black, so I put back on 4.2.
Thanks for your help
rebirthan1x писал(а): 04 июн 2024, 20:55 Hello
After installing version 4.2, go to SETUP and select your receiver model on one of the pages. If necessary, you can install any firmware version.
