Hello
I have a problem after updating to firmware 4.2. The FM Radio is not working after the update, only white noise ( I came from 4.17 ). I choose the right hardware in setup.Have some else the problem? Is it possibe to downgrade? If I try it, the screen went black, so I put back on 4.2.
Thanks for your help
ATS25 max-Decoder II FM Radio Firmware 4.2Beta
After installing version 4.2, go to SETUP and select your receiver model on one of the pages. If necessary, you can install any firmware version.rebirthan1x писал(а): ↑04 июн 2024, 20:55 Hello
