NEED SUPPORT
NEED SUPPORT
stf_ats200 писал(а): ↑24 июн 2024, 06:39 but Generic Model is all that is selectable
This is wrong. you can choose ATS200 model rotate the encoder. The ATS200 is a must. This is also available in SETUP
stf_ats200
NEED SUPPORT
Сообщение stf_ats200 »
Binns,
Selecting the ATS200 via the encoder wheel was all I had to do, and my radio is now working again!
Thank you so much!
Sam
stf_ats200
NEED SUPPORT
Binns et. all,
With the ATS200, is there a means to tell the radio to take a snapshot of the display and save it in it's filesystem, that then can be pulled back to a Windows computer?
Thank you. Sam
NEED SUPPORT
stf_ats200, No, It is Immpossible
stf_ats200
NEED SUPPORT
Binns,
Thank you. I was wondering how the images for the User Manual were acquired.
When you write it's impossible, I presume it is a restriction of memory, still I would think a possible alternate might be "light" communication protocol over the COM port to a receiving program running on a Windows computer.
Sorry for the questions:
Is it possible on the ATS200 model with the H-Radio software opened with the License, to enter Digital Modes?
Really appreciate the outstanding support.
Best regards,
Sam
NEED SUPPORT
stf_ats200 писал(а): ↑25 июн 2024, 16:38 Thank you. I was wondering how the images for the User Manual were acquired.
These are just photographs. Reading information from the screen memory is not involved in the receiver circuitry.
stf_ats200 писал(а): ↑25 июн 2024, 16:38 Is it possible on the ATS200 model with the H-Radio software opened with the License, to enter Digital Modes?
You need to install a decoder in this receiver
stf_ats200
NEED SUPPORT
Binns,
I'm confused, what do you mean by decoder.
What is going on in your video here:
https://youtu.be/olw2Cdx3eN0
Are you saying the ATS200 can run the software, but does not have the same hardware as a 120D ?
I was under the impression it was merely software that accomplished this.
Thanks,
Sam
stf_ats200
NEED SUPPORT
Binns,
Never mind. I realize now that the 120 was modified with a decoder circuit and becomes the 120D. I mistakenly thought that since the A200 was the next step up in the numbering system, it would have a decoder built in. Evidently it does not, and according to the designer of the decoder board, I believe (but not sure) incompatible with the ATS200.
Sam
NEED SUPPORT
stf_ats200,
aircatz
NEED SUPPORT
Сообщение aircatz »
hi hope you can help
i have ats200 got from amazon
just updated with key to 4.2 great quick responce from admin
all ok but no digi and i cant get any wif it show very poor signal
is it possibe the seller on amazon gave me amodel with no decoder board and if so where can i get a decoder from
many thanks for any help in advance
Anthony
