This is wrong. you can choose ATS200 model rotate the encoder. The ATS200 is a must. This is also available in SETUP
NEED SUPPORT
NEED SUPPORT
stf_ats200
NEED SUPPORT
Binns,
Selecting the ATS200 via the encoder wheel was all I had to do, and my radio is now working again!
Thank you so much!
Sam
Thank you so much!
Sam
stf_ats200
NEED SUPPORT
Binns et. all,
With the ATS200, is there a means to tell the radio to take a snapshot of the display and save it in it's filesystem, that then can be pulled back to a Windows computer?
Thank you. Sam
Thank you. Sam
stf_ats200
NEED SUPPORT
Binns,
Thank you. I was wondering how the images for the User Manual were acquired.
When you write it's impossible, I presume it is a restriction of memory, still I would think a possible alternate might be "light" communication protocol over the COM port to a receiving program running on a Windows computer.
Sorry for the questions:
Is it possible on the ATS200 model with the H-Radio software opened with the License, to enter Digital Modes?
Really appreciate the outstanding support.
Best regards,
Sam
Best regards,
Sam
NEED SUPPORT
These are just photographs. Reading information from the screen memory is not involved in the receiver circuitry.stf_ats200 писал(а): ↑25 июн 2024, 16:38 Thank you. I was wondering how the images for the User Manual were acquired.
You need to install a decoder in this receiverstf_ats200 писал(а): ↑25 июн 2024, 16:38 Is it possible on the ATS200 model with the H-Radio software opened with the License, to enter Digital Modes?
stf_ats200
NEED SUPPORT
Binns,
I'm confused, what do you mean by decoder.
What is going on in your video here:
https://youtu.be/olw2Cdx3eN0
Are you saying the ATS200 can run the software, but does not have the same hardware as a 120D ?
I was under the impression it was merely software that accomplished this.
Thanks,
Sam
Thanks,
Sam
stf_ats200
NEED SUPPORT
Binns,
Never mind. I realize now that the 120 was modified with a decoder circuit and becomes the 120D. I mistakenly thought that since the A200 was the next step up in the numbering system, it would have a decoder built in. Evidently it does not, and according to the designer of the decoder board, I believe (but not sure) incompatible with the ATS200.
Sam
Sam
NEED SUPPORT
hi hope you can help
i have ats200 got from amazon
just updated with key to 4.2 great quick responce from admin
all ok but no digi and i cant get any wif it show very poor signal
is it possibe the seller on amazon gave me amodel with no decoder board and if so where can i get a decoder from
many thanks for any help in advance
Anthony
Anthony
