ATS25 Max Code
skibo6911
ATS25 Max Code
Сообщение skibo6911 »
I purchased the activation key rom atsxley@gmail.com, however the code does not work. Both of us have been trying to figure out why the code does not unlock the radio, when entered it refers me back to this web site. Has anyone else had this problem and is there a fix for it?
73
Ron
Coolidge, AZ USA
ATS25 Max Code
skibo6911 писал(а): ↑31 мар 2025, 01:51 when entered it refers me back to this web site
This means that the activation key is already used on another device.
skibo6911
ATS25 Max Code
I thought as much, I even asked if there was another key code. So I guess a wasted $25. Why can a get a proper code?
Atsxkey
ATS25 Max Code
Сообщение Atsxkey »
The Key was valid, you have over 50 mails from me, including manual to read
Atsxkey
ATS25 Max Code
Сообщение Atsxkey »
I have speak with Antonio Russo to check again and reset key.
He new about..
Atsxkey
ATS25 Max Code
Сообщение Atsxkey »
I have sent this to you
can make firmware update to your radio ?
this is exemple how to do it
https://www.youtube.com/watch?v=gSsTPOS ... rnardBinns
________________________________________________________
instaler
http://harduino.ru/files/H-RADIO/v4.2/H ... _setup.exe
_______________________________________________________________
instalation manual
http://harduino.ru/files/H-RADIO/v4.1/M ... al_ENG.pdf
________
usb driver
CH341SER driver (ATS25/ATS120)
http://harduino.ru/files/TOOLS/CH341SER.zip
CP2102 driver
http://harduino.ru/files/TOOLS/CP2102.zip
_______________
activation manual
___________
radio manual
http://harduino.ru/files/H-RADIO/v4.1/M ... O_4.16.pdf
activation video
https://www.youtube.com/watch?v=Cs2dEO6 ... rnardBinns
overview of firmware functions
https://www.youtube.com/watch?v=mOOGiMQ ... rnardBinns
press subtitle button on youtube for see subtitles
Atsxkey
ATS25 Max Code
Сообщение Atsxkey »
Antonino Russo tell me to contact him end help you to activate, because you do not finish the activation
The code from radio need to insert on activation page on website. And recive code to insert on radio.
All are in manual.
I sent to you in private link for Fb. To contact Antonino
Do not forget to make me know when succeed to activate
73's
