FW 4.21 - HF-Fax Decorder
hellocity
Сообщение hellocity »
I’ve already upgraded to firmware version 4.21 and saw in the changelog that “- The HF-FAX decoder has been added.”
However, I can’t find the HF-FAX option in the MODE menu. How can I use this feature?
Thanks.
hellocity писал(а): ↑08 ноя 2025, 04:37 I’ve already upgraded to firmware version 4.21 and saw in the changelog that “- The HF-FAX decoder has been added.”
Thanks.
MODE-DIGI-SSTV- MODE------ scrol with TUNE-----WEFAX288, WEAFAX576.
hellocity
OK
Последний раз редактировалось hellocity 08 ноя 2025, 18:48, всего редактировалось 1 раз.
hellocity
Arvi писал(а): ↑08 ноя 2025, 13:35 MODE-DIGI-SSTV- MODE------ scrol with TUNE-----WEFAX288, WEAFAX576.
Thanks for your help, I’ve found the FAX mode.
However when I set the bandwidth to 1200 and then switch to SSTV mode, the bandwidth automatically changes to 4000.
Is there any way to keep it at 1200?
hellocity писал(а): ↑08 ноя 2025, 18:47 Thanks for your help, I’ve found the FAX mode.
Great that you found it. I can't give any more advice because I don't use SSTV/FAX mode. I need RTTY, FT4/8 and CW decoding first. Can anyone else who uses FAX advise?
IZ2IDS
Сообщение IZ2IDS »
ANCHE IO HO AGGIORNATO A 4.21 , NON L'HO ANCORA PROVATO MA APPENA SO QUALCHE COSA TI INFORMO A PRESTO DA CARLO IZ2IDS 73
PS: IO ERO INTENZIONATO ALL'ASCOLTO SULLA BANDA DEI 70 MHZ ,VISTO CHE SONO RADIOAMATORE E POSSIAMO IMPEGNARE TALE FREQUENZA, VOLEVO SAPERE SE C'E' UNA PROCEDURA PER IMPOSTARE FMN , PERCHÉ SE VADO SULLA FREQUENZA APPENA CITATA , L'IMPOSTAZIONE VA IN AUTOMATICO IN FMW PER LA RICEZIONE DELLE RADIO BROCASTING
