I’ve already upgraded to firmware version 4.21 and saw in the changelog that “- The HF-FAX decoder has been added.”
However, I can’t find the HF-FAX option in the MODE menu. How can I use this feature?
Thanks.
FW 4.21 - HF-Fax Decorder
OK
Последний раз редактировалось hellocity 08 ноя 2025, 18:48, всего редактировалось 1 раз.
Thanks for your help, I’ve found the FAX mode.
However when I set the bandwidth to 1200 and then switch to SSTV mode, the bandwidth automatically changes to 4000.
Is there any way to keep it at 1200?
Great that you found it. I can't give any more advice because I don't use SSTV/FAX mode. I need RTTY, FT4/8 and CW decoding first. Can anyone else who uses FAX advise?
ANCHE IO HO AGGIORNATO A 4.21 , NON L'HO ANCORA PROVATO MA APPENA SO QUALCHE COSA TI INFORMO A PRESTO DA CARLO IZ2IDS 73
PS: IO ERO INTENZIONATO ALL'ASCOLTO SULLA BANDA DEI 70 MHZ ,VISTO CHE SONO RADIOAMATORE E POSSIAMO IMPEGNARE TALE FREQUENZA, VOLEVO SAPERE SE C'E' UNA PROCEDURA PER IMPOSTARE FMN , PERCHÉ SE VADO SULLA FREQUENZA APPENA CITATA , L'IMPOSTAZIONE VA IN AUTOMATICO IN FMW PER LA RICEZIONE DELLE RADIO BROCASTING
