Can someone teach me how to enable the new Functions (Bluetooth, LNA, Hi-z) ?
I can't switch them to on
And what is ment with Screen Morroring and how it work ?
Regards and 73 from Germany
Will those Features come to ATS25 ?
You can't get the spectrum just by connecting the si4732 audio output to pin 32 esp32. Audio should be supplied to pin 32 only after amplification and normalization within 3.3 volts. If you have an ATS25 receiver, then you don't need to add anything to setting.ini
I have the ATS-120 receiver, not the ATS-25.Binns писал(а): ↑26 июл 2023, 20:43 You can't get the spectrum just by connecting the si4732 audio output to pin 32 esp32. Audio should be supplied to pin 32 only after amplification and normalization within 3.3 volts. If you have an ATS25 receiver, then you don't need to add anything to setting.ini
