Funtions in FIRMWARE FOR ATS25 и ATS120 version 4.16 / 23.07.2023
DO1RHC
Сообщение DO1RHC »
Hello together.
Can someone teach me how to enable the new Functions (Bluetooth, LNA, Hi-z) ?
I can't switch them to on :(
And what is ment with Screen Morroring and how it work ?
Regards and 73 from Germany
DO1RHC, New Bluetooth and LNA features are available in the ATS120, as well as in future receiver modifications that are currently being tested. Screen mirroring is used for non-standard screens, which are sometimes used in homemade receivers.
Jarbol
Сообщение Jarbol »
After updating ATS25x2 to the final version of 4.16, I have a problem with the language selection. Despite uploading other languages, the only one available is English. I have reset the radio to factory settings. It didn't change anything. It was fine with the beta version. Out of curiosity, I loaded version 4.16Beta, but the problem persisted. Any ideas?
SP6VWN
Jarbol, You should use the language files from the archive with the firmware that you are installing. They are different and will not work with other firmware
Jarbol
Сообщение Jarbol »
I had no such problems before. And the language files themselves have a simple structure. I had no problems with the language files in the beta. I'm trying to figure out what happened.
Problem solved. Corrupt lang.tmp file.
Последний раз редактировалось Jarbol 25 июл 2023, 11:05, всего редактировалось 1 раз.
SP6VWN
DO1RHC
Сообщение DO1RHC »
Binns писал(а): 24 июл 2023, 11:14 New Bluetooth and LNA features are available in the ATS120
Will those Features come to ATS25 ?
DO1RHC, This is a question for manufacturers. As far as I know they are working on it
Zoltan
Сообщение Zoltan »
Let's say I don't care about decoding, and I only want to see the audio spectrum. I route the audio to pin32 of the ESP module. What setting do I have to enable in the ini file so I can enable this feature?
Zoltan писал(а): 26 июл 2023, 18:34 Let's say I don't care about decoding, and I only want to see the audio spectrum. I route the audio to pin32 of the ESP module. What setting do I have to enable in the ini file so I can enable this feature?
You can't get the spectrum just by connecting the si4732 audio output to pin 32 esp32. Audio should be supplied to pin 32 only after amplification and normalization within 3.3 volts. If you have an ATS25 receiver, then you don't need to add anything to setting.ini
Zoltan
Сообщение Zoltan »
Binns писал(а): 26 июл 2023, 20:43 You can't get the spectrum just by connecting the si4732 audio output to pin 32 esp32. Audio should be supplied to pin 32 only after amplification and normalization within 3.3 volts. If you have an ATS25 receiver, then you don't need to add anything to setting.ini
I have the ATS-120 receiver, not the ATS-25.
On the schematic I got with the firmware, the audio goes through from the output of the LM386 through a 1uF coupling capacitor, and then goes in to pin32. From the datasheet of the LM567, I can see some resistors from V+ to pin3 to bias Q32. Are you using this voltage as "zero" for the ADC? Does this settle to Vcc/2?
Also, on this pin, I am measuring some data at around 10 MHz, presumably from the internal flash. I haven't tried yet, but I don't think this modification will work with this radio.
