This is a feature of the si4732 chip. The SSB signal display on the S-meter is improved on receivers with a decoder installed due to the built-in spectrum analyzer. There is no decoder in the ATS120.Potan писал(а): ↑21 авг 2023, 17:58 When receiving amateur stations on HF bands, in ssb s mode, the meter shows only the noise level, and does not respond to the difference in signal strength of amateur radio stations. When receiving FM stations, the readings change depending on the signal strength.
Funtions in FIRMWARE FOR ATS25 и ATS120 version 4.16 / 23.07.2023
Hello Mr. Binns,
I'm using Firm 4.16 on a receiver based on my friend Silvio's PCB to decode the FT4 and FT8 digital signals.
This version of the software is amazing!
Would it be possible to implement a function to send the decoded reception data to the https://pskreporter.info website as the JTDX software sends?
It would be interesting to inform the community about how ionospheric propagation is going in the HF bands.
Thank you very much for your attention!
73 from PP5NW - Rod
73 from PP5NW - Rod
Yes, we are working on it. I think this is a very useful feature.RodFns писал(а): ↑23 сен 2023, 19:33 Would it be possible to implement a function to send the decoded reception data to the https://pskreporter.info website as the JTDX software sends?
Pregunta general: Cómo activo las funciones de Banda aérea, 2 mtrs, 6 mtrs, y UHF.?
Dichas funciones están apagadas en el dispositivo pero están presentes en el menú. Qué necesito para activarlos.?
Mi ATS25 Max Encode 2 está recién actualizado Gracias a alguien de este foro que me vendió una licencia.
Ti2ICE
San José, Costa Rica
Ti2ICE
