1500 рублей. Можно заказать через Авито, ссылка есть на сайте. Можно забрать самостоятельно в Люберцах МО. Либо пишите в личку куда отправлять, договоримся.
Уважаемый Binns, когда будет свежая прошивка для приемника? На одном обзоре видел 4.17.
Instalkino
Hi, I have a general question about the firmware.
I have ordered an ATS25 AMP. My understanding is that the firmware version displayed on the unit will be “4.17 Air beta”, but it is actually “4.16 Air” with the LNA and HiZ features enabled.
Will the “4.17 beta / 07.11.2023” from the Harduino site work on the ATS25 AMP with the LNA and HiZ features?
At the moment, the H-RADIO firmware that you can download on the website does not support the LNA and HI-Z functions in ATS25 AMP. Pay attention to the header for which receivers this firmware is. The ATS25 AMP receiver uses experimental firmware. You should wait for the 4.17 non-beta version to appear.G8PTN писал(а): ↑18 ноя 2023, 02:06 Hi, I have a general question about the firmware.
Thank you for the fast response, very much appreciated.
All understood on the firmware status. I will wait until there is an updated version that supports the ATS25 AMP hardware.
Hello! Здравствуйте!
I plan to take the ATS25AMP versions. Я планирую взять версии ATS25AMP.
Tell me, is the additional PCB for CW reception already built-in/inserted into this receiver or does it need to be purchased separately?
Подскажите дополнительная печатная плата для приема CW уже встроена/вставлена в данный приемник или ее нужно покупать отдельно?
The circuitry for the CW/DIGI reception is already on the PCB of the ATS25 AMP. It is using an experimental version of V4.16 Air for the additional features. It will allow CW, RTTY, FT8 decode without any firmware update. Hopefully future H-RADIO updates will also support the ATS25 AMP hardware.
Добрый день, подскажите. Раскопал тут экран у себя поставил и вот такое. На другом 4 дюйма все норм.
Прошивал и 1 пунктом и 2-м и 3-м. И 1.16 и 1.17
Дальше заставки не проходит. Ставлю другой экран все работает.
