ATS25 AMP mistake update
radi0
Сообщение radi0 »
G8PTN писал(а): ↑17 фев 2024, 15:00
radi0 писал(а): ↑17 фев 2024, 14:27 I have just looked at the datasheet of the decoder (HT567) it has a minimum operating voltage of 4.75 volts it must be replaced by an LM567 in the datasheet of this component its minimum voltage is 3.5v instead of 4, 75 v minimum for the original HT567 component to be tested
Yes, although is should be noted that the electrical characteristics for the LM567 are shown with a minimum voltage of 4.75V.
The LM386/HT386 is also operating below its specified minimum voltage of 4V.
there is also the LMC567 in the Recommended Operating Conditions the chip operates at 2 volts
phpBB [video]
radi0 писал(а): ↑17 фев 2024, 17:01 there is also the LMC567 in the Recommended Operating Conditions the chip operates at 2 volts
The component alternatives should be possible.
I am not too sure why the LM386 was used for the audio amplifier, it does not need to drive a low impedance load. A basic op-amp amplifier should be adequate. Adding a small bread board with an alternative circuit for the Digi Decoder is an option.
It may be possible to implement the CW/RTTY tone detection in the ESP32 using DSP, the HT567 could then be omitted.
The minor issue of backlight flickering and reboots when the battery voltage gets low will still occur, but this is at the tail end of the discharge curve.
masya_v
Сообщение masya_v »
Здравствуйте! Подскажите пожалуйста как можно изменить вращения инкодера ? При вращении вправо громкость уменьшается и также частота уменьшается - работает наоборот
slartibartphast
Сообщение slartibartphast »
there is an option in settings to reverse it
ikuclja2
Сообщение ikuclja2 »
SETUP/Encoder reverse
masya_v
Сообщение masya_v »
Доброго дня, сегодня решил обновить прошивку,все получилось но возникла проблема с отображением спектра ,что поправить? Спасибо
Может кто выложит свой файл setting ?
Последний раз редактировалось masya_v 08 мар 2024, 13:28, всего редактировалось 1 раз.
masya_v писал(а): ↑08 мар 2024, 12:49 Доброго дня, сегодня решил обновить прошивку,все получилось но возникла проблема с отображением спектра ,что поправить? Спасибо!
в чем заключается проблема? в настройках включен декодер?
masya_v
Сообщение masya_v »
Binns писал(а): ↑08 мар 2024, 13:27
Кнопка не активна.И ещё не работает декодер.
Binns писал(а): ↑08 мар 2024, 13:27 в настройках включен декодер?
SETUP -> ДЕКОДЕР -> Декодер CW и DIGI
BOBA1958
Сообщение BOBA1958 »
Здравствуйте Binns! Купил 2 приёмника (лицензия) ATS25 AMP. Продавец предупреждал - никаких обновлений прошивок! Установлена 4,17 Air beta. Руки чешутся. Не смотря ни на что, я решил обновить до 4,2. Обновил. Теперь не переключаются входа Hi-z на 50 ом и не включается LNA. Как вернуть китайскую прошивку? Второй приёмник не прошивал. Возможно ли с него скачать заводскую прошивку и залить в первый?
