FM lower limit frequency in retro mode on ATS-25amp
drelectron3
I am using ATS-25amp with version 4.2, and I would like to set the lower limit frequency of FM in retro mode to 70MHz, but the current setting is 87.5MHz. How can I set it to 70MHz?
drelectron3, Enable the FM range from 64 MHz in the menu settings.
drelectron3
I set FM from 64MHZ in the SETUP Menu, but it still starts from 87.5MZ on the RETRO screen.
![Изображение]()
Turn on 64 MHz, , NEXT, search <<DN and that's it. That's how it worked for me.
drelectron3
Your screen is a VHF screen, not an FM screen. I can also display from 64MHz if it is VHF. The FM screen is probably from 87.5MHz.
drelectron3
IN VHF, the maximum freqencey is up to 87 MHZ INSTEAD.
I live in Japan.In Japan, the FM band must range from 70 MHz to 108 MHz.
This means you need to adjust something in the program for the Japanese FM range, I can’t help you here.
