ats25 wifi data
radi0
ats25 wifi data
Сообщение radi0 »
Is there a possibility of sending via the wifi connection (without using the USB cable), the data (FT8, rtty, cw..) to a terminal :?:
73,s
ats25 wifi data
radi0 писал(а): ↑04 мар 2024, 17:47 Hi,
73,s
There is no such possibility now. But an application for remote connection is being developed. This feature is planned in the application
radi0
ats25 wifi data
Сообщение radi0 »
Binns писал(а): ↑04 мар 2024, 19:15
73,s
Thank you for the answer
8-)
ponti
ats25 wifi data
Сообщение ponti »
I have installed a digital BT adapter and use it to transmit e.g. FT8 via Bluetooth to a smartphone and tablet.
Data transfer via A-Explorer is also possible.
It works perfectly.
ats25 wifi data
ponti писал(а): ↑05 мар 2024, 23:09 I have installed a digital BT adapter and use it to transmit e.g. FT8 via Bluetooth to a smartphone and tablet.
Please tell us in more detail how you do it
ats25 wifi data
HI,
Something like the very cheap JDY-31 Bluetooth module connected to the serial data pins of the ESP32 should work.
I am not sure if the CH340 output would need to be disconnected, or if it is high impedance when not driving.
radi0
ats25 wifi data
Сообщение radi0 »
It works perfectly.
thank you for your help, I need to order a bluetooth adapter
73,s
ponti
ats25 wifi data
Сообщение ponti »
yes, somthing like this..if you have Problems with USB Cummunication after Install the BT Module, put a Diode in the RX Line, Kathode to the BT. TX Line its fine.
But in my case it works without.
ats25 wifi data
There was an attempt to use the built-in Bluetooth in the ESP32, but so far there is no solution to the problem of insufficient memory of the microcontroller
